First, it's really fantastic that there isn't any french support.
I purchased my Z1 in December 2013, anything was perfectly okay except since yesterday.
He was covered by fingerprints and I simply pulled it under water for like 10 little seconds with all holes CLOSED, like always. (I do this it everytime)
About an hour later, battery just fall to 40% right to 8%.
I obviously puted him in charge but he didn't want to charge itself (I tried different wires).
Then, the battery was blocked to 1% for hours but he still had power, I used it for a complete hour this morning, he just finished to discharge itself this morning, now I can't even switch it on.
I'm **bleep**ed.
You have to perform a software repair using PC companion.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable.
The thing is that he doesn't want to charge, at all.
If the device does not charge even after being connected at a wall socket for some time,you have to stop by a sony service:
