Problem while updating Xperia E using PC
Biserka
Hello everyone! I tried to update my Xperia E by using PC, but something got happened and phone's USB cable suddenly disconnected from PC while updating process still was not finished. I had to turn off my phone and start this process from the beginning, but now phone won't work when I turn it on. I removed battery and also a SIM card, but it still won't work, only appears "SONY" and it lights up when its turned on, and that's all.:smileysad:
I don't know what to do, please someone to help me if had an experience with this. Thank you!
Thommo
Genius
Try performing a system repair as this will often fix issue after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
