heating problem question
andrei1989
Screenshot_2014-05-05-13-32-21.pngScreenshot_2014-05-05-13-32-28.pngScreenshot_2014-05-05-13-32-21.png
what the **bleep** is this media thing and how can we shut it off. with the screen closed and after many many normal and forced restarts my phone is heating very much and as can you see i have a batery life of 3 hours(i repeat not doing anything on it). until now i managed to restart it a few times and stop this stupid heating thing, but now it won't give up. please help
34 REPLIES 34
andrei1989
i have used for 24 hours an sd card from my other smartphone and it didn't got hot...i hope it will never get that hot with no reason. what can be the reason for the sd card to get corrupted like that?
profile.country.RO.title
_alexdon_
It could be related to what you have written on it or simply some incompatibility issues.What card was it again?
alexdon
GeoffH
Enthusiast
I have struggled with this heating - charging - battery drain issue since the KK update, it has been an unmitigated disaster from day one
I have taken several steps to cure the issue and although I thought I had on several occasions it does rear it's head again, ultimately I believe it has something to do with the wtite restrictions on the ext SD card which I very strongly resist and disagree with - if want to buy a memory card and install it in my phone it has got nothing to do with google ast what I choose to put on it and how   they have made a huge policy error right there
Here are my findings after going through the motions for several weeks to get a working and stable phone
First - under 4.3 firemware I had no issues and my phone was very stable
I also have a Smartwatch connected - which complicates the issue, and a 64gb sandisk ext SD
After updating to KK I had the following major issues
- The phone was constantly warm (draining the battery) on standby
- When using the phone it got very hot - the screen brightness dimmed (saving power) and very sluggish
- When on the charger sometimes I had to turn the phone off to charge it as there was not enough ebergy from the charger to compensate for the huge battery drain - a warning was also displayed on the screen
- If I did manage to get it charging without turning off it was very slow to charge
- manually unmounting the ext SD sometimes fixed the issue
- I did a complete facoty reset and update repair (no apps installed) - no change
- removed all content from my ext SD card and wiped it with the phone (reformat)
- scanned all the content that was on the sd card on my PC looking for errors - none found
- copied all content back to sd card - still had problem
I noticed that in settings/power management/battery the mediaserver was always active 40% and dowload
throughout this period I did have times when my phone was stable and operating normally but maybe only for a few days
Still no apps installed
I went into settings/apps/all and disabled as many as I could - still problems
Then I discovered a setting in setting/accounts/google/Ads and ticked the "opt out of personal based ads" and I thought I had fixed the issue, my phone was normal for weeks...............but
I copied a new album onto my music folder on ext SD and all the issues came back described above - 12 tracks of music in MP3 format - to fix this I moved the album to my internal sd and left it there for a few days then moved it back - no more problems
I believe the issues described above are caused by no one single thing, I think it is a collection of problems that appear showing similar symptoms which make this a very complicated issue, ultimately I believe the fault is with google and their very poorly written code  - if you do a search on the net you will find that these problems also exist on their own devices - so it is not exclusively Sony
Further - just recently after an update to Skype and Chrome my phone has now started doing a reboot cycle - it seems this happens after I use skype but at this moment not verified
I also had a new problem were the daily alarm I had set could not be turned off when it activated and the screen remained blank, the only way I could stop the alarm was to hit the reset button and reboot the phone
I believe these last two recent issues are conneted
All in All KK upgrade has been a horendous experience for me and I'm sorry I didn't stay with 4.3, it is a daily effort to keep this phone functioning and useable - but I must also conclude that IMO the blame for this KK debacle lays firmly with google - the reason for my conclusion is a simple one - these issues are not exclusive to Sony
ghani667
well hope sony software team finds this issue and inprove battery life because even after uncheking google adds battery drain didnt solve that much
andrei1989
my sd card was a no name class 10, 64gb card and now i have teste a kingston class 10, 32gb card and it is all ok for now
