Hello,
How fast is your quick launch mode on your xperia p? (from sleep to capture)
Mine takes 3 to 5 sec before it captures a photo. Tried reparing with pc companion
but nothing happened.
And it has been 2 weeks since i got my xperia p but the bottom cap
Of my XP is a bit loose on the right side. I can hear it creak. I dont put
My phone in my pocket. Nor taking the cap off. I always have a case for
My phone. I dont know how that happened since the other side of the cap
Is not loose nor creaking. I dont know what to do. It's annoying.
Sometimes when i play a game or open an app it crashes.
i also have one more problem- the music seems to hang a bit when i am working parallelly with the phone... do u have the same??
Music hangs only when I am using facebook. All other time it is working fine...
bine hangs even when i unlock the screen...
My music doesn't hang while im playing or using facebook, try repairing, i used SUS.
That is not the case with me. You can check if any particular application is taking too much memory.
try to look if you have many applications running on RUNNING SERVICES,..
and uninstall application you don't use.
SUS??
Sony Update Service,, I use that because i can't repair my phone using PCC
@Nitman and @Sagar
Can you post here if the replacement cap fix the loose and creaky problem of our Sony Xperia P.
Thanks a lot. I need to sleep for my report on school tomorrow.
oh and when you get the replacement key can you check if it fits perfectly, and the right side not longer than the left. Thanks!:smileyhappy:
sure ryan...
