Battery Drain
Battery Drain
Hi all,
I´ve received my Sony Xperia P 2 days ago in Germany from Amazon Germany. Everything seemed to be working fine but unfortunately if the phone is in standby as well as when it´s being used, the battery drops rapidly and the phone shuts down after approximately 8 to 10 hours. Turning 3g off, wirless off, switching to wcdma or gsm only does not fix the problem either. As I have read this problem occured with the Xperia S as well which was then fixed by a firmware update to the version 6.0.A.3.73. Since the phone has been released here 2 days ago only there are basically no complaints about this issue with the P yet. Is there any solution planned already? I guess Xperia P users can´t use the same firmware of the S since the build has got a "B" instead of the "A" in it.
Sony - is there a firmware update in the pipeline to fix the ridiculous battery life of the Xperia P or do I need to return it?
Thanks a lot..
Ra
59 REPLIES 59
That's not normal, i have a battery drain of 1% in 1.5-2 hrs
Some process is draining battery (widget, backgound sync..)
Check battery usage, remove unwanted widget and check running processes
ryan515
hi thanks for replying, can you post screenshots of your battery usage and/or phone setting?
Well at least some more people with the same issue... I´m wondering why Sony is not releasing this update as uliwooly provided the link some posts above that one:
http://www.ptcrb.com/vendor/complete/view_complete_request_guest.cfm?modelid=21034
The problems you can find in different forums are:
1. Battery drain
2. Phone randomly turning off
3. Screen turning green when brightness being tuned up
It´s really sad that Sony in incapable of updating the devices even some weeks after the realese!!! Nobody wants to wait for ICS which has been pushed back as well contrary to the promises made while selling the phone!
Here you are battery stats and services running
I removed nearly all widgets (timescape, guide, recommender) except google bar ant time widget and uninstalled some useless stuff like recommender
screenshot_2012-06-02_2216.pngscreenshot_2012-06-02_2218.pngscreenshot_2012-06-02_2218_1.pngscreenshot_2012-06-02_2219.png
Sony should go to 3rd party companys to create more powerfull battery for this phone, atleast give us the option to replace the battery by our selfs or by a repair shop or something.. otherwise Sony is doomed.!
I really dont understand why they put in such battery in a hi-tech phone?? saving money on batterys is the most dumbest thing to do in the smartphone buisnes, i would pay 100$ extra for 300 mah extra power.
ryan515
hello, we almost run the same application,
now i have 33% battery left, battery use is 11hrs. with normal usage, wifi on, using web, playstore, playing games, donwloading games, instagram, facebook, messenger etc.
sometimes i leave it at least 2-3 hrs on stand by with wifi on (sometimes off)
is my battery good?
Doesn't seem so bad, it depends.
Anyway todat i experienced high battery drains, 3% in 20 mins standby with 3g on.
I closed 'Smooth calendar' and drain is bacl to normal
ryan515
today, when i was in school i put it on stand by for 9-10hrs then when i got home i play with it with some games like temple run, now battery use is 16hrs and have 32% left, looks pretty good to me... i don't use livewallpaper..
by the way, i just notice the bottom cover feels loose.... why is that?
Sony - one simple question:
When´s the update to 6.0.B.1.576 coming???
you will get the same answer as other 2011 Xperia users waiting for ICS, is your phone locked to a network? if it is contact your network
http://talk.sonymobile.com/message/199357#199357
If you find your SI in the released software table the software for your device is released and available in PC Companion and Bridge for Mac where you can update your Xperia™ Smartphone.
We will continue to add items in the list as soon as they are released.
We will however not be able to answer on questions like: "When will SI number XXXX-XXXX be added to this list?" or "when will country X get the update?"
