Battery charging
Richieh
Battery charging
Recently updated to 5.1.1but now battery won't charge from usual charger or from computer USB. It will only charge from my tablet charger, any ideas?
14 REPLIES 14
Richieh
Micro USB cable into phone USB into charger. Also the computer doesn't detect if the phone is connected to it either
@Richieh
Is the cable loose when you connect it to the phone? (does it wobble)
John-BR
Hi @Richieh
Welcome to the community.
I would suggest checking to see if these issues are coming from the hardware of the handset.  We have a build in feature called Xperia Diagnostics to help with this.
  • Go to Settings > About phone > Diagnostics.
  • Tap Test device.
  • Select the tests for the charging
  • Follow the on-screen instructions.
Could you let us know what the results of that are?
Richieh
I tried the diagnostic test but it doesn't recognise the original chargers as being connected. I know the cables and chargers are OK because I plug them in to my last phone and it starts charging straight away. This has only started since I installed an update last week
@Richieh
Follow @John-BR's advice and contact your local Xperia care
