In the last few weeks I've been experiencing frequent issues with my bluetooth and wifi. My phone forgets my bluetooth headset and I have to resync to get it to work. As well with my wifi it will have authentication issues with my router. I often have to restart my phone to fix both the bluetooth and the wifi issues.
This is getting extremely frustrating. I only bought this phone at the end of August and it's already having issues.
Silvercloak
I have 2 Xa1 ultra phones, one for wife and one for myself. Both have been restored to factory, and have oreo (so thought that would help) but have cleared cache for BT and Midi and shut off the autoscan and still have bluetooth connectivity concern. So rediculous, she even has Sony radio in explorer and won't connect periodically. I have a Gear S3 watch that loses connectivity repeatedly. Clearly an issue with Bluetooth, is there any help out there, my phones are under warranty.
It's a very weird problem, but clearing the BT cache in the the BT and BT midi system apps definitely clears the issue for me. The problem still comes back every few days after doing this - so it's not a perfect solution. I'm hoping Sony releases a real patch to fix this sometime soon - as it's a great phone outside of this issue.
Such poor experience for first Sony phones. It's hard to tell that to my wife when all she's had in the past is a phone that has no Bluetooth issues.
How do you clear BT cache? Apparently i'm not Smart enough to deal with it myself.....
Go to Settings, Apps & Notifications, App Info, tap the 3 dots in the upper right corner and select Show Sytem, look for Bluetooth and Bluetooth Midi Service, go into both and select Clear Data.
Sorry to report that it very much does apply in Android 8.0 - I've upgraded and still have the same problem
definitely not a perfect solution, takes way too long and as you say it recurs after a few days!
Please Sony fix this ASAP
Same Problem here. Car Radio wont reconnect, if you have a watch connectet. And my Headset reconnects every 15 sec. and after some reconnects the Bluetooth crashes allways.
Am also experiancing the same problem with wifi...it jst gos off...whenever i try to switch it off it freeze da fone
