Hi everybody,
I'm having some issues with the battery drain of my xperia x compact, at least i think so. As you can see in the picture the "phone standby" (at least i think it translates like that" is allways nr1 in battery consumption. It's like it keeps the phone allways on and doze doesn't start. Is it normal?
I did a factory reset and nothing changed. Thanks for any help
I found a nice app called better battery stats that analyse the battery consumption. It says that doze works fine and the phone dies go in deep sleep. The problem looks to be my provider. The phone has almost allways a poor signal and at best moderate signal. Right now I'm in roaming too which increases even more the battery consumption
You might take a look at what is running in the background.
Settings-> developer options->Running services
Explanation here, and on many other sites.
Thank you for the answer. I did that and am uninstalling some apps one by one to find the guilty one. For now nothing changed, but i'll let you know if anything changes.
also make sure to go into the individual apps via the apps listings and disable background activity on ones you don't want running in the background, most of the things are set to run whenever they want, apart from the messages, clock, launcher, phone, etc all mine are set to only run when I want
An update, i didn't find any "guilty" app. Uninstalled all the apps that were running for some time, disabled the bluetooth but nothing changed
