Hi guys,
Please help me I bought a xperia ARC S white and ever since day one is went to no boot stuck @SE screen ,
had to reload the firmware to .58 version and then it ran for a day and then once again te issue purists back to square one .
had to reload the firmware day by day and works flawless and stops working .
please help .
firmware is LT8i_4.0.2.A.0.582(2.3.4) kernel build .283.
Tried the wotang still the same used flash tool it’s the same not sure what to do please help!!!!
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
2.3.4 4.0.2.C.0.5 LT18i & LT18a
http://talk.sonyericsson.com/message/133669#133669
Xperia Arc LT15i/a & LT18i/a 2.3.4 4.0.2.A.0.62 minor update
http://talk.sonyericsson.com/thread/29197
for future reference
Make sure you backup everything
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
I have updated the firmware to LT18i 2.3.4 4.0.2.A.0.58 using the SEUS and its working now need to check and will keep you updated
Initially i had used the link below and loaded the firmware
http://talk.sonyericsson.com/message/146849
it worked for 3 days and went to no boot.
have tried with LT8i_4.0.2.A.0.42 and 166 build all exhibit same issue loaded through flash tool .
Not i have used the SEUS and im testing it do i need to update to .62 build or be with .58 build.
.62 its the latest
Updated firmware from
Running on the 4.0.2.A.0.58 firmware and its very stable now for almost 2 days so far so good hope this resolves the issue.
Running and scdeduled back up after each software update its seems to be stable now no issues so far battery back up is almost 1.5 days fairly good .
A big thanks to uliwooly this issue is resolved You rock .
one question can this be rooted using the zergRush method to add custom ringtones and files it that recommended or will that cause any stablity issues on the phone Please suggest if there is any other stable firmware for the ARC S that is fast,stable and lite weight.
My sony arc S went back to no boot after almost a month
had to reload firmware using hte SEUS.
Pleas help how to back up the entire firmware so that some thing goes wrong i can just restore with out making any changes
Thank you
Any one Please help me !!!!!
Xperia ARC S is once again is no boot issue this time I can't even use the SEUS or the flash tool both fail
Its stuck at sory ericsson logo.
here is what i get from Flash tool v6.
11/015/2012 13:15:58 - INFO - <- This level is successfully initialized
11/015/2012 13:15:58 - INFO - Flashtool Version 0.6.6 built on 2012-01-08 19:34:23
11/016/2012 13:16:00 - INFO - Device connected in flash mode
11/017/2012 13:17:18 - INFO - Selected LT18i_4.0.2.A.0.58(2.3.4)_HK.ftf
11/017/2012 13:17:18 - INFO - Preparing files for flashing
11/017/2012 13:17:23 - INFO - Please connect your device into flashmode.
11/017/2012 13:17:23 - INFO - Start Flashing
11/017/2012 13:17:23 - ERROR -
11/017/2012 13:17:23 - ERROR - Error flashing. Aborted
11/017/2012 13:17:24 - INFO - Device connected in flash mode
11/017/2012 13:17:42 - INFO - Selected LT18i_4.0.2.A.0.58(2.3.4)_HK.ftf
11/017/2012 13:17:42 - INFO - Preparing files for flashing
11/017/2012 13:17:47 - INFO - Please connect your device into flashmode.
11/017/2012 13:17:50 - INFO - Start Flashing
11/017/2012 13:17:50 - ERROR -
11/017/2012 13:17:50 - ERROR - Error flashing. Aborted
11/017/2012 13:17:51 - INFO - Device disconnected
11/017/2012 13:17:53 - INFO - Device connected in flash mode
11/018/2012 13:18:33 - INFO - Device disconnected
11/018/2012 13:18:39 - INFO - Selected LT18i_4.0.2.A.0.58(2.3.4)_HK.ftf
11/018/2012 13:18:39 - INFO - Preparing files for flashing
11/018/2012 13:18:44 - INFO - Please connect your device into flashmode.
11/019/2012 13:19:01 - INFO - Device connected with USB debugging off
11/019/2012 13:19:01 - INFO - For 2011 devices line, be sure you are not in MTP mode
11/019/2012 13:19:18 - INFO - Device disconnected
11/019/2012 13:19:19 - INFO - Device connected in flash mode
11/019/2012 13:19:20 - INFO - Start Flashing
11/019/2012 13:19:20 - INFO - Flashing loader
11/019/2012 13:19:22 - INFO - PROT_VER="03";DATE="20110217";TIME="15:47:00";VER="R4A066";CXC="1234-5769";TYPE="S1_LOADER";UNIQUE_DEV_ID="CB0438B44E93DB136EA5FD287978F5D1AB4B7F0B";SEC_LOCK_STATUS="LOCKED";OTP_DATA="4B6D7100471404E81508042840A2958FB001002000000000";IMEI="35850604836635";AID_VERSION="0004";EROM_AID="0001";LOADER_AID="0001";SW_AID="0001";CUST_AID="0001";SIM_LOCK_AID="0001";HWCONF_AID="0001";PROD_ID="0001";ACTIVE_LOADER_AID="0001";MEMDEVS="02:00:002C:00B3:0000:00002000:00020000:00000800:00000040,03:03:001B:534D:0010:0001DA60:00010000:00000200";MAN_ID="002C";DEV_ID="00B3";SIN_VER="0001";AID_TAMP="NOT_TAMPERED";MAX_PKT_SZ="00010000";AUTH_LEVEL="NONE";AUTH_MET="0001";CARD_PRESENT="YES";CARD_SIZE="8GB";CARD_DATA="UHJvZE5vPTEyNTUtNjI3Mg1Qcm9kUmV2PVI0QQ1Db3BpZWRCeXRlcz02NDQ0MDIxODANQ29waWVkRmlsZXM9MTg1MzANQ29waWVkRGlycz0xMDENT3JkZXI9OTAyODkzOS0xMA0=";LOADER_ROOT="S1_Loader_Root_773f";EROM_ROOT="S1_EROM_Root_d601";SW_ROOT="S1_SW_Root_883f";CUST_ROOT="S1_Cust_Root_9603";SIM_LOCK_ROOT="S1_SL_Root_c422";HW_CONF_ROOT="S1_HWConf_Root_08af";BIM_STATE="DISABLED";
11/019/2012 13:19:22 - INFO - Flashing adsp.sin
11/019/2012 13:19:25 - INFO - Flashing kernel.sin
11/019/2012 13:19:27 - INFO - Flashing amss_fs.sin
11/019/2012 13:19:27 - INFO - Flashing fota1.sin
11/019/2012 13:19:28 - INFO - Flashing fota0.sin
11/019/2012 13:19:29 - INFO - Flashing apps_log.sin
11/019/2012 13:19:29 - INFO - Flashing amss.sin
11/019/2012 13:19:38 - INFO - Flashing cache.sin
11/020/2012 13:20:03 - INFO - Log written to Z:\andrid xperia update firmware\Flash tool latest 6.0.6\Flashtool\flashtool_2012-02-10_01-15-58.log
11/020/2012 13:20:34 - INFO - Flashing system.sin
11/022/2012 13:22:41 - INFO - Flashing userdata.sin
11/022/2012 13:22:41 - ERROR - ERR_SEVERITY="MAJOR";ERR_CLASS="MEMORY_CLASS";ERR_STATIC="HASH_VER";ERR_DYNAMIC="Failed to init erase";
11/022/2012 13:22:41 - ERROR - Error flashing. Aborted
11/022/2012 13:22:41 - INFO - Please connect your device into flashmode.
11/022/2012 13:22:42 - INFO - Device connected in flash mode
Please help I dont know if this is hardware of software .It looks to be a software issue biut not sure.Please help me !!!
Thanks in advance .
take both sd and sim cards and try again with Flashtool
