upgrading "Error" for SE Live Walkman ??
heera_rana
Hi all,
please help me out ,
when i'm trying to update 4.0 its showing message as software error "failed"
should i need to select option "USB debugging " in Application setting -->Development-->USB debugging
or not ??
38 REPLIES 38
heera_rana
i'm getting this following error ~    Slightly_frowning_Face
can you post a picture of SUS
heera_rana
what does it means ??? will it not connect directly ??? there is no "NEXT" button to click cause my
phone is not deteceting Slightly_frowning_Face
don't run neither pcc nor sus
turn off your phone -> press and hold the volume down key -> keep holding it, now connect the usb cable while still holding, does the LED turn green? if it does
go to control panel -> add a device -> it might show up on the list it might not, once it finds your phone follow the steps to download the drivers
remember to restart your PC if you just installed SUS
heera_rana
yup...you are right i need to switch off my mobile and then need to connect USB by holding the down volume key respectively and now i got connected and showing to upgrade new version ...
its an lengthy size 219 mb ... download is going on..thanks for making me happy Slightly_smiling_Face and spending valuable spare of time for me and your valuable comments too Slightly_smiling_Face
anytime, enjoy ICS once you get 4.0.4 check this thread
Xperia S Music App 4.0.4 leaked, does it work with your Xperia?
http://talk.sonymobile.com/thread/38259
and don't forget to mark the correct and useful answers
i have installed the package......wat next
still the pc companion not working n sus is showing d same error......pls help
which package? did you restarted  your computer?
d one i downloaded through xda site
i indtalled it using device manager
n rebooted
still nothing is happening
d same error message for sus
n error for companion
try a different computer maybe?
