upgrading "Error" for SE Live Walkman ??
heera_rana
Hi all,
please help me out ,
when i'm trying to update 4.0 its showing message as software error "failed"
should i need to select option "USB debugging " in Application setting -->Development-->USB debugging
or not ??
don't run neither pcc nor sus
turn off your phone -> press and hold the volume down key -> keep holding it, now connect the usb cable while still holding, does the LED turn green? if it does
go to control panel -> add a device -> it might show up on the list it might not, once it finds your phone follow the steps to download the drivers
remember to restart your PC if you just installed SUS
38 REPLIES 38
hi same prob here plz help....
try Update Service instead
Connect your phone in MTP mode, no need to connect in USB debugging mode..
Also, make sure that your phone is getting deteceted in Pc suite. Slightly_smiling_Face
heera_rana
can any one help out here !!!
i'm waiting for reply .......if u know answer please reply ASAP !!!
heera_rana
okay..thanks for information Slightly_smiling_Face
i will do now and let you know if i face any problem Slightly_smiling_Face
heera_rana
still i'm facing the same problem , while my phone is getting deteceted in Pc suite and avaiable to upgrade 4.0 while upgrading it shows ERROR as "unable to install or start phone software update components "
what does it menas ???:(
have you tried SUS? SUS its not PC Suite
heera_rana
okay i will try SUS ...and let u know !! Slightly_frowning_Face
