Hi all,
please help me out ,
when i'm trying to update 4.0 its showing message as software error "failed"
should i need to select option "USB debugging " in Application setting -->Development-->USB debugging
or not ??
yeah i downloded SUS and installed software , but while connecting my phone through USB cable its not detecting my phone ...its showing message as
1.turn off the phone and wait atleast 30 sec
2.connect the micro USB cable to a USB port on your PC
3.press and hold the volume down key on the phone while plugging the USB cable into your phone ???
i'm totally confused ...help me out
simple turn off your firewall and antivirus
once it asks you to connect in flashmode turn off your phone press and hold the volume down key then while still holding connect the usb cable, don't release the volume key
hey...em olso facing d same problem
i.e failed software download
n even my SUS is not running.....it shows some error n asks to see some log file....
pls help....:smileysad:
Now you have to install the driver for S1boot download...
You can use the USBFlash_driver.zip given in this link for installing device driver for your device. http://forum.xda-developers.com/showthread.php?t=1239715
Hope this helps.
yes i desabled firewall and antivrus too,
but it didn't asked me to connect flashmode which u mentioned above and it not connecting my phone too !!!
i downloaded flash driver ...were should i install now ?
i mean in my phone or PC ??
how far does it go?
It should be installed in your PC.. install it through device manager...
i think it should be installed in phone ???
while installing in PC i'm getting some error and failed to install !!
