My Xperia P is not switching on
manik20051991
When i switched on my phone my device is just showing xperia color logo that is showing on starting of phone but there is no furter process is going on.now i cant switched on my phone. How can i solve this problem??
Alexander1
Power off your phone by press and hold the power button and volume up until you get 3 vibrations. Charge the phone for a couple of hours and try to start it again.
If the problem persists, try to repair the phone software using PC Companion:
In PC Companion, press start on Support Zone > Start on Update the phone/tablet software > Press the blue link that says "Repair phone/tablet".
11 REPLIES 11
Alexander1
manik20051991
is it working if my device is turned off? because my device isnt switched on even now
profile.country.RO.title
_alexdon_
PC companion will not work if the phone is off,SUS will:
alexdon
Alexander1
PC Companion should work with the phone turned off as well. You just have to follow the steps described above without the phone connected to the PC and a guide will start giving you instructions of how to proceed. But SUS will work also. Slightly_smiling_Face
bosskingtonayab
My experia keeps restarting itself unless I put it in flight mode. I cannot use it for calls now, is there any way out?
Tags (1)
_alexdon_
Remove the SIM,check again.
alexdon
bosskingtonayab
I have already done that but it did not help.
_alexdon_
Try a software repair.
alexdon
Alexander1
Just to clarify, you did run your phone without a SIM card inserted and still the restart occurs?
