Help! i can't connect my phone to the android store powered by google play.
when i click "Install" of a app with my computer a pop-up message says that i have to connect my phone to the server by choosing the white shopping bag app icon in the phone's menu.
in that app i entered my e-mail address(which is the same address as this account) and password and then clicked "sign-in"
but after about 2 minutes it say's "Can't establish a reliable data connection to the server"
but i can surf through the internet by using the browser in the phone so it can't be a problem with my internet connection isn't it?
what should i doooooo?
p.s- my phone is xperia mini pro
how do i take a screen shot??
if you have android 2.3.4 press and hold the power button -> tap on screenshot
if you have 4.0 press and hold BOTH power button & volume down
Thank you very much dude. resetting worked. now i can go to the android market and d'load apps. thanx.
is it ok to update into ICS?
if yes which should i use, pc companion or update app in the phone
either or work the same
a quick suggestion backup your current firmware
http://talk.sonymobile.com/thread/38251
you might not like laggy ICS and you might want to get back to GB
i have 2.3.3 so it doesn't work?
and what's "->" you mentioned? there's no a arrow in my touch screen when i hold power buttton.
-> or > I use them to mark: do this THEN do that THEN do this THEN etc
that's odd that you have 2.3.3 and not 2.3.4, run SUS or PCC and update
Update Service (SUS)
when i hold power buttton there comes a menu with 3 options.
1. power off
2. airplane mode
3. silent mode
and no "screen shot"
Indeed because you have android 2.3.3
k. thank you verymuch for helping me:smileyhappy:
As soon as i enered this thread and i saw the answer as correct
I was like
You will have to use pc companion as you can't update to ICS through Update center app of mobile
you can use SUS as well
And it's you wish to update to ICS
I am on ICS and it works quite fine
Or since you are new to gingerbread as well, use it for a month OR SO and then later upgrade to ICS
