Audio PROBLEM!!!
Audio PROBLEM!!!
Hi, after i ugrade ti the nes ICS 4.0.4 the sound disappeared in the phone!! I  did reset, does not help. What should I do?
test your phone with Service Menu
http://talk.sonymobile.com/thread/24534
http://talk.sonymobile.com/thread/44888
10 REPLIES 10
profile.country.PH.title
MarlonUk1
Have you checked on the settings?
try repairing your phone again using SUS,
Yes, i checked the settings and repaired again with SUS, does not help.........
Markus1
Leader
All sounds at all points? If you restart the phone, will it work for some time again before going silent?
Can you still make phone calls and hear the counterpart? If you activate the speaker phone, does it work? Can you listen to music with a headset? Speaker?
More info please! Slightly_smiling_Face
When I reboot the phone still no sound, it was one time he appeared in 5 minutes and then again has disappeared.
I can make phone calls and i hear the counterpart.
I can listen music with a headset, but not with Speaker!
The speaker just does not work.
The phone only a month, he did not fall, do not swim ...
Written Speaker and all. No sounds
There are any ideas what could it be?
this seems to be hardware related, take it to a sony repair center ASAP
Yes, this is a hardware problem, I trotted him a little) and the sound appeared and immediately disappeared. Thank you for your help.
