Z5 Premium; Headphone Jack does not Auto-Detect after last update
AzimB
I've had this issue since the last update/build.  When I plug in headphones, it does not auto-detect and sound continues to come out of the phone speakers.
This is NOT hardware related.  I downloaded 'Sound About' and I can manually turn on my headphone jack and it works fine that way.  But the auto-detect still doesn't work.  This is definitly software related.
I tried this with a dozen headphones and the issue persists.
28 REPLIES 28
Emir1
Hero
Hi @AzimB,
I am sorry to hear that.
Could you try to reboot the device in safe mode to see if it persists there as well? In case it does, I would suggest that you try a software repair using Xperia Companion.
OlgaPenkrat
I Have the same issue. After restart the app headphones detects, but if I turn off them or stop playing music they disappears again. And I should restart phone once again.
Emir1
Hero
I'm sorry to hear that @OlgaPenkrat,
Could you try what I suggested in my previous post as well?
AzimB
Will the software-repair reset my phone?
Illicit
I have the same issue as the original poster after the update! I have to use soundabout to circumvent the issue...................
Anish98
My phone is having the same problem!!!
It happened after the maintainance update.
Emir1
Hero
Hi @AzimB, I am sorry for the late reply.
Yes, performing a software repair using Xperia Companion will delete all locally stored data, so I strongly suggest creating a backup using Xperia Companion prior to repairing the software.
@Anish98 and @Illicit, did you have the opportunity to try to see if the same occurs in safe mode, and a software repair if the safe mode did not help?
Keep me updated regarding how it went!
Anish98
Yes I did try it in safe mode and the same thing happened. I'm not sure if it is hardware or software. But I tried it with sound about and it did work.
Emir1
Hero
If the above suggestions did not help, then I recommend that you get in touch with your Local support in order to be assisted in sending the device to an authorized service center. Once there, a service technician can have a look at your device and find the root of the behaviour.
