  • Z5 Dual, hangs severely after 7.1 update!
Options
  • Mark Topic as New
  • Mark Topic as Read
  • Float this Topic for Current User
  • Subscribe
  • Mute
  • Printer Friendly Page
Go to solution
Ali28
Ali28
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
  • Report Inappropriate Content
July 2017
July 2017
Hello fellow SONY users.
I have updated my Sony Xperia z5 Dual to 7.1.1 last week and it worked pretty well for a day or two. Battery consumption is better now.
BUT!!!
Unfortunately, this happiness didn't last long. After two days my phone suddenly hanged severely and even home screen disapeared (Xperia launcher). The phone became extremely slow so that none of the applications worked.
I tried software repair via my PC again. It became good again. but after a 24-hour working with my phone, this problem happened again. Although by restarting the phone the phone become stable but after a day, it will hang again!
I tried uninstalling some applications as well to see whether the problem exist or not, but that didn't help.
I don't know what causes the problem to the phone. I hope Sony make a further update available soon to solve this problem.
Thanks.
1 Kudo
Reply
  • All forum topics
  • Previous Topic
  • Next Topic
Ali28
Ali28
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
Guys, the problem os with the MOVIE CREATEOR app.
Disable it and problem will be solved.
5 Kudos
Reply
35 REPLIES 35
No57
No57
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
Hello,
I did the Android system update yesterday. Since I have huge slowdowns, applications that close, my battery that empties very quickly and it also heats ..
What should I do to solve this problem?
thank you in advance
GT
1 Kudo
Reply
Fatbat
Fatbat
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
I also updated my z5 compact to 7.1.1 on 7 July 2017 and have the same problems. The phone hangs and is very slow to the point it it very difficult to use even for phone calls and sms. Cannot get keyboard up.  Restarting the phone improves the situation for only a very short time before it reverts back to hanging and slow. I have plenty of space so that shouldn't be an issue.
Pretty disappointed as this phone has been flawless for 18 months and is now barely usable because of an update!
Help.
1 Kudo
Reply
Julia6
Julia6
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
Hello,
My problem after last week update, it is if I  want to delete pictures from my folder, I can't. The pictures are deleted only after I restart the phone.  How can I do to be back to normal.?
2 Kudos
Reply
tx99
tx99
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
I had same issue. Booted to safe mode (hold power button, then long press on power off).  Safe mode worked fine.  I noticed several apps updated (like 10).  Some for scrolling and crashing issues.  I rebooted to normal mode and it's great again. So something in cache cleared with the safe mode reboot or one of the apps was causing it.  But it's good now, so see if it works good in safe mode.
3 Kudos
Reply
Davidher2
Davidher2
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
Problems after update nougat 7.1.1
Hi!! I have un little problem, I updated my Z5C to nougat 7.1.1, I had a good performance, but two days after, I suffered from excessive memory usage of System, Before the update, it was about 600-800mb, but now it gets high up to 1.2gb, leaving few memory apps, I repeated with Xperia companion but this problem appears again , I have seen that many persons have this same problem.
I wait for help
Thanks
2 Kudos
Reply
Spectrum1
Spectrum1
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
My z5 compact has the same problem. After the update the performance of apps became really jittery. I checked the ram usage and the new op system is using most of the device memory.  What good is it if you can no longer use Apps?
2 Kudos
Reply
DarthAkshay
DarthAkshay
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
I've updated my phone to 7.1.1 and after that the phone is heating alot and the battery is draining very fast because of that.  Sometimes some applications freezes and the phone stops responding.  Please let me know if this thing gets fixed.
Thank you
1 Kudo
Reply
tx99
tx99
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
What happens if you boot into safe mode? See if your phone is fast in safe mode.
Reply
Jard001
Jard001
  • Mark as New
  • Subscribe
  • Mute
  • Highlight
  • Print
July 2017
July 2017
I've had the same issue for the last couple of days after updating, phone has been unusable at times. I used CCleaner to clean up cache and RAM then manually deleted the app cache (settings>storage>internal shared storage>cached data) and phone seems to be back to normal now.
Reply
  • « Previous
    • 1
    • 2
    • 3
    • 4
  • Next »
1898629posts
