Z3 Compact not able to do things while on call
jayycopeland
I've noticed with my Z3 Compact that it doesn't allow me to really do anything in a call. Like reply to a text, etc. Where as with other android devices, and apple products I have been able to do while doing same things. It allows you to get into message I believe but won't type anything in. Definitely not just a touch screen issue. Any ideas? Hoping lollipop fixes this issue. Any idea when that update is too?
Phy
Legend
Legend
From your Home screen
1. Tap the Application screen icon.
2. Find and tap Settings > Apps.
3. Swipe to the All tab.
4. Find and tap on an app called smartkey.
5. Uninstall it.
6. Restart the phone
6 REPLIES 6
You should be able to multitask, so you have a protective case or film that might be blocking the proximity sensor?
jayycopeland
Its nothing to do with the proximity sensor. I take phone away from ear and phone comes on. And im able to do things normally without being on phone. And I can navigate thru phone on a call. It just wont allow text or such
Phy
Legend
Legend
5. Uninstall it.
jayycopeland
Thanks Phy. Seems like that did the job. What does smart key even do?
Phy
Legend
Legend
No problem. Glad it worked. And don't worry about smart key it is usually for headphones.
fawwaz
Thanks phy .. I have faced the same problem and has been fixed using your smart solution .. You are genuis .
