I've not taken mine apart but some devices have a small coax type cable connecting the antenna to the board, A lot like the connectors you'd see on a laptop and the wifi card
Is it possible that the GPS antenna pins or connections aren't touching or is it a case of it simply won't turn on, If it is then your phone thinks there's no GPS device connected so can't turn on something that isn't there
Awsome - Glad you got it sorted
Hi i have a similar issue. Can anyone tell me if the small shiney foam pad on the lower board with the shiney coating makes a connection to anything or is it to just hold the board in position.
Thankyou!
