Xperia Z WiFi wont turn on
KiliYT
Hello,
today I was reseting my Xperia Z and as I want to add my Wifi, the Wifi want turn on so I reset my phone another time and the same problem returns! I don't no what to do now can anyone help me?
KiliYT
20 REPLIES 20
sonyhafsa
i have same problem, wifi does not get connect since my phone received last update on  9.9.2014 its kitkat Slightly_frowning_Face
Guru71
Hi, my problem appeared after upgrading to Android 4.4.4 - Firmware 10.5.1.A.0.292 now I was more 'can use Wifi or Bluethoot, I try to enable it after a few seconds are automatically disabled, the thing is very irritating. What can I do to fix this? Until the Android version 4.3 - firmware 10.4.1.B.0.101 I had no problem and the phone worked perfettamente.Vi please help me Thanks
JLSR
i have the same problem. I need to connect to internet through my phone but my wi fi can't turn on. I already tried PC  Companion but it doesn't work :(.
How can we solve this problem Sony?
Qlovejam
I have the same problem of not allowed to turn on the Wifi button to connect home wifi.  It says on my phone that "a security policy is restricting the wifi usage!
I tried to restart for several times and no changed.
I cannot use the wifi connection.......and i only bought this Z1 for 10 days!  It worked well until two days ago; it keeps restarting itself for several times in the days.  Anyone can help.......?
@KiliYT wrote:
Hello,
KiliYT
baunach1
@ uliwooly
so, finally my Xperia Z has a working WIFI and bluetooth after I put in "Safe Mode" with the instructions in your link!Does it has to be like this all the time?
Do you have a solution so I don't have to be in "Safe Mode"? My software is C6603_10.5.1.A.0.292 that from what I understand is the latest & greatest from Sony.
Please help me to find a way to use my Xperia Z in a normal way!
Joakim
flinshow
hie, l have sony experia z3 which is not switching on WiFi button. How can I solve the p
roblem
IMY655468
how do u flash it???
Tags (1)
Mhendraaa19
my sony xperia z3 wifi wont turn on,i've update the firmware but it still wont turn on
can anyone fix it?
Ndawnd
So anyone get info how to solve the unworking WiFi after update kitkat? Please help
Fifi2016
Where did you find that? I did a full repair today and still nothing!
