it could be a hardware issue, but you could repair your phone with PCC and check again
Bridge (for Mac)
The SD card might be corrupted, does another SD card work? does this SD card work with other phones?
does your phone recognize other SD cards?
if you insert the SD card on other phones, can they access the files?
Boot in safe mode and see if the card is working fine:
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Bridge (for Mac)
If PCC doesn't work then contact your local Xperia Care
