SD card, help!!
day1
SD card, help!!
My xperia z1 doesn't recognize my memory card, the device memory just keeps calculating and never works! I put a discography there and I can't hear it, what do I do?
it could be a hardware issue, but you could repair your phone with PCC and check again
PC Companion (PCC)
Bridge (for Mac)
8 REPLIES 8
The SD card might be corrupted, does another SD card work? does this SD card work with other phones?
day1
It's not corrupted, the SD works in other phones, the problem is on my device
does your phone recognize other SD cards?
if you insert the SD card on other phones, can they access the files?
profile.country.RO.title
_alexdon_
Boot in safe mode and see if the card is working fine:
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
alexdon
day1
My phone don't recognize any other SD card, and yes, the other phones can access the files normally
day1
Boot in safe mode didn't work either
PC Companion (PCC)
Bridge (for Mac)
If PCC doesn't work then contact your local Xperia Care
