Proximity sensor issue resolved :)
phantomrocks
Big daddy resolved it Slightly_smiling_Face
You have to sacrifice resetting the phone using the Sony PC software 1st. Avoid data backup from old accounts.
Then, after the reboot is done and Android is reinstalled with update x.x.x.534 goto the dialer & type *#*#7378423#*#* then press dial
In the menu that will come go to calibration and then choose proximity sensor. (If you run the test it might give error = -1) Then, set settings to default and it may ask to reboot the device.
After reboot type *#*#7378423#*#* then press dial. In the menu that will come go to calibration and then choose proximity sensor do the test and it will show success. VIOLAAAaaaa!!!!
Check the phone...it works Slightly_smiling_Face
Have tested this and the issue is resolved on my phone finally ....yippieeeeeee!!!
76 REPLIES 76
xavinux
Enthusiast
Hi @Deejar
Have you check this link ?
http://forum.xda-developers.com/showthread.php?t=2458660
What version of Android are you running ?
If my answer was helpful for you, please thank me with Kudos.
I'm at disposal for any question.
Best Regards,
Deejar
Hey,ive tried that but it doesnt show that.it says proximity sensor off.android 5.1.1
Barcelona503
So i was curious and ran the test all of them work except the light sensor, when i try the ear Proximity it works and it passed. How can i fixed the light sensor test? when i go to the service setting after dialing that number it works fine. also those this issue have to do withe smart calling handling to fail? i tried it a couple of times and still doens't work.... any solutions???? thanks
Khayam
Hello Dear,
I need your help as i updated my 5.1.1 and facing the aproximity sensor unproper working i also dail the *#*#7............. but ther is no colabaration show me there and i am completly unable to resolve the issue.
waiting for your kind support
Sullynidz
Have the same problem! I did a hard reset but still nothing.
On dialing the code..the calibration option is no longer available. How else can one calibrate the proximity sensor? xperia z running Android lollipop
FU1
Hi. My Sony z3 is having a problem with the front sensor. It goes off when I am placing a Call or answering a call. Pllleeeaase Need Help
Armini
Xperia Z Ultra C6833 - Android 5.0.2
Try if this incredibly simple method will work for you:
1) Go into SERVICE TEST - proximity sensor. Your sensor is shown as ON continuously?
2) Get a small piece of black electric isolation tape (10x10mm). Glue it directly on the spot of the proximity sensor.
 Your sensor is now shown as "OFF" in the SERVICE menu? Lucky you. Remove the Tape. Sensor ON? Your life is saved.
3) OK, here comes the fine tuning. Get a punch plier. Choose one of the little punches, around 2mm. Perforate a tiny circle of 2mm diameter of the black tape. Positioning it on the left lens of the double-lensed proximity sensors, it will give you the chance to test if the sensor will react if you touch it with your finger.
If the sensor is continuously on, cut the piece of tape some smaller with a cutter knife or a sharp scissor. This all can be done while the sensor test routine is running on your phone, no need to reboot etc.
If you are patient and work meticulously, you will be able to receive full function of the sensor with ear on / ear off to the phone.
4) I placed the tape spot directly into the left side of the cutout for the proximity sensor of my additional screen protector foil.
 Works like a charm.
Good luck!
JJX3PLUS
I changed the screen had a proximity Fault followed this forum to find the problem. and now have permantly fixed using Prroximity sensor reset. Works absolutely fine now. No More black screen when making calls . Thanks All
Taylormade1
Happened to mine, if you don't want the factory reset, simply lie the phone on its back. Screen up, it lights up, not ideal but functions can be used
ALIXPERIAZ
Hi I,m having issue in my SONY XPERIA Z C6602 , as its updated to 5.0 version .. whenever i dial a number my phone screen goes black and call is on but when i want to close or dial any other number i have to press the power button twice and then it shows lock screen .
can any one confirm how to fix this issue   as some time my proximity sensor work other wise its mostly close.
can any one call me on this and provide the solution or whats app me the steps to resolve the issue . ASAP.:smileyworried:
PLEASE
