Proximity sensor issue resolved :)
phantomrocks
Big daddy resolved it Slightly_smiling_Face
You have to sacrifice resetting the phone using the Sony PC software 1st. Avoid data backup from old accounts.
Then, after the reboot is done and Android is reinstalled with update x.x.x.534 goto the dialer & type *#*#7378423#*#* then press dial
In the menu that will come go to calibration and then choose proximity sensor. (If you run the test it might give error = -1) Then, set settings to default and it may ask to reboot the device.
After reboot type *#*#7378423#*#* then press dial. In the menu that will come go to calibration and then choose proximity sensor do the test and it will show success. VIOLAAAaaaa!!!!
Check the phone...it works Slightly_smiling_Face
Have tested this and the issue is resolved on my phone finally ....yippieeeeeee!!!
76 REPLIES 76
Patriot1669
There is no option for calibration when I key in the code. I'm using Xperia Zr.
Coolzed76
Same for me. I don't have the calibration menu on my Xperia z5
Anyone can help?
happyYear2017
Hi
my mobile is Ultra Z when i type *#*#7378423#*#* i have the menu but without calibration Menu Slightly_frowning_Face
can you help plz
Thanks
Shaneela
I dont see the calibration option after dialing that code.
3Darts
I don't have "proximity sensor" in the menu, the closest thing to it is   "proximity switch" and when i choose it   says "proximity switch is on"   then goes back to menu so my problem didn't get fixed
ROGERHINDOkawai
I have the c6833, but with the numeral that you suggest in my computer does not give me the option of the calibration of the proximity sensor, so it does not work for me. Is there any other way to solve it? I'm desperate and annoying at the same time ... HELP!
abdlmnam_2010
Hello my friend I bought my phone safe mode but the same problem how I can to fix sensor proximity but idont forget my data and thx very much
Kenyonzki
The code doesn't give me access to calibrate, I'm on android v 7 is there a different code now?
F16
Hi I followed your I structions (thanks by the way )  I get service tests -proximity switch then an audible sound and just writing saying proximity switch on ? Any help much appreciated
Miyktv
It didn't work for me!
I have z5,
I didn't findthe calibration test,
I run the proximity sensor,
Any suggestions?
