Problems with Exchange Activesync contacts
ManFromNorth
I am using two different accounts on my Z2. The first one is my GMail account. Everything's perfect avout this. Second is my Exchange account. Here I figured ut that the Z2 des not sync my contacts. I checked all settings for the account and contacts are marked to be synced, but without success.
Has anybody an idea of what could be the probelms?
Thansk for your input.
BR,
Christian
33 REPLIES 33
Rickard
Is the problem that contacts on your Exchange account are not downloaded to the phone or that contacts you add in the phone are not uploaded to the account? When you add a contact in the phone you need to select which account to store it to (just below first and last name).
ManFromNorth
Hi Rickard,
the problem is that I do not see the contacts from my exchange account. When I add a contact on the phone and assign this.as an exchange contact it does not appear in Outlook.
Bring,
Christian
Rickard
That sounds strange.
What if you add a contact to your Exchange account in the phone, let it sync, remove the account from Settings -> Exchange ActiveSync -> [your account] -> [menu] -> Remove account and then add the account again. Do you see the contact you added to the account again in your phone?
ManFromNorth
I just created a contact and synced the exchange account. After that I deleted the whole exchange account. The contact was then not longer visible on the phone.
Then I created the exchange account again, set all preferences properly and did a new sync.
The contact did not show up again. I think it was not synced to the exchange server before I deleted the account.
Very strange, since all syncs work well with the.Gmail account.
ManFromNorth
What if I delete the Gmail account and force to sync to exchange? Are all apps gone when I delete the Gmail account?
Rickard
I doubt removing the Gmail account will help. As the contact was removed when you removed the account it was added to the correct account but as the contact was not restored when you added the account again it shows that the synchronization of contacts with Exchange is not working.
Would it be possible for you to see if this also happens with a colleagues account in your phone?
ManFromNorth
It's kind of weird. I tried another user. This also did not work. Then I deleted all my accounts on the Z2, including Google. After creating my Exchange Account, the Z2 synced everything perfectly, including all contacts!!!
After that I set up my Google account. I saw that from that point on, the Z2 did not sync contects with Exchange any longer. So I again deleted the Google account, re-configured it and unchecked the box "sync contacts" before it started the first time to do so.
Now, everthing seems to work fine. I do not need my Google contects to be sync'd. I can live with that even if I have no clue about the reasons... Thinking_Face
Rickard
That is very strange indeed but i'm glad to hear that you managed to get sync working.
Could you please send me a PM with the following information so that i can forward it for further investigation:
Name:
Phone nr:
E-mail:
Country:
Operator:
IMEI nr:
Build number:
jayeffkay
One scenario is that the sync is working fine, but the active filters in your device phonebook might prevent the EAS contacts to show when you have synced a Gmail account.
Please try:
Have all desired accounts synced (gmail EAS hotmail)
Open phonebook
Click More Options to the lower right corner
Click Filter
Find your EAS account and check the "All contacts" checkbox
Let me know if it helped.
