I agree with Alexdon, repair the phone with PCC
Bridge (for Mac)
Please stop asking about lollipop in other threads than here:
About the battery issue,have you tried a software repair?
Bridge (for Mac)
Performing a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
