I just upgraded my Z5 compact, and lost all mobile data access.
EDIT: I'm located in Norway and have Telenor as the operator.
I've tried rebooting my phone, often after each setting change, with no effect.
I've tried:
- Checked the data provider
- Turned off and on again Mobile Data
- Turning off Roaming
- Turning off Power Saving
- Changing to 3G only
- Changing to 4G
- Redownloaded Internet Settings from the network provider
- .. and probably more
Nothing seems to work. There doesn't seem to be a problem with my network provider, which I didn't expect as it happened immediately (I think - had mobile access some hours earlier) after upgrading.
Is someone else experiencing the issue and/or knows a fix?
Finaly a fix working on my phone..
Setttings -> More -> Mobile networks -> Access Point Names. Select "telenor.smart"
Edit: APN from "telenor.smart" to "telenor". save (top right corner) Done..
I tried updating the internet settings from Telenor (for the third time since yesteday?), and now it works again.
