Hi everyone,
I have Z1 for one year, and it was really nice time, recently i upgrade to Lolipop 5.0.2, but then the mic stop working good.
If i make or recieve a normal call, the other side can not hear me well, the vocie is bad and sometime its gone totally.
But if i try to recode a voice or movie or even make an internet call using Watts App or Facebook massenger, the mic is okay and fine.
Only in regular call it stop working good.
Any help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try turn off the Microphone noise suppression and Speaker voice enhancement this will temporarly fix the problem
I'm tired of the incompetence of developers Sony, they turn a smartphone with top-end filling in a frank
Wait from one version to another android bug fixes and receive in addition to new ones.
Tired of me that Sony is constantly fed with promises.
The same camera module that Z1, on the smartphone cheap Chinese work better,than Z1, and all gnarled hands of programmers.
Dismiss them to and find those who are able to work normally.
Edited due to foul language been used
I have bought Xperia Z Ultra recently and it came packaged with Lolopop 5.0.2. Not sure if this problem was always there or it is the result of upgrade which I can see in the thread. I am also facing the same issue. No one is able to hear me on the other side. I will try the options listed above and will come back if this works fine. Do we have a permanent solution to it ? Also, in Z Ultra I do not see the option of Xloud and other sound enhancement. is it by design?
me either, i also incountered this problem after the lollipop update 270 firmware.. in the normal call, the other line cannot hear my voice clearly..most of the time are chappy or disturted sound..even i turned off the noise susspension and voice enhancement..i also made the through pc companion but it didnt solve the issue...i also changed the network GSM wcdm prefferd GSM.. wcdm etc. but its the same...
I / WE HOPE THAT SONY WILL FIX THIS ISSUE...COZ ITS VERY ANNOYING AND WE CANNOT AFFORD TO BUY ANOTHER MOBILE ANYMORE ECXEPT FOR THOSE WHO HAVE LOT OF MONEY...PLEASE SONY FIX THIS AS LONG AS POSSIBLE...
Same problem here.
Microphone quality in voice calls (as heard by the other side)
worsened dramatically after system update to Lollipop 5.0.2 in Xperia Z1. Already
tried: disabling noise suppression & another update via PC Companion -
no effect. Switching preferred network type to "WCDMA only" does solve
the call quality problem, but makes phone virtually unusable outside
of urbanized areas (at least in Poland). Call quality in Skype is always fine.
Another, less critical nuisance after updating to Lollipop 5.0.2 is a
several (4 - 5) seconds long lag before showing SwiftKey on screen
keyboard when opening conversation or clicking any editable field of a webpage.
The problem didn't exist in KitKat 4.4.4. I haven't checked the Xperia
default keyboard behavior.
Any news, when the problems are going to be solved? Can somebody from
SONY respond on the forum.
Sometimes reinstalling the latest update with PCC smooth things out
Bridge (for Mac)
