Lollipop charging bug ???
m3lm
After lolipop update I can't charge the phone to full, i already made a clean setup via pc companion after i resetted the phone.
My phone goes to 84% and starts blinking charging/notcharging, so finally after 10 h of charging it has only 85% of accu. Anyone had the same?
I recorded this video to show u my problem
https://m.youtube.com/?#/watch?v=SQ6iQrqPKT4
P.S i can charge my mobile while its turned of ..
Also im sure there are no apps is consuming the battery while im charging it .
Please fix this with an update or just tell is what to do..
Tags (1)
460 REPLIES 460
hedrox87
Nope, didn't do the red button stuff... I'll try it immediatly.
If the phone is broken someway, shouldn't it be broken all the time? Why having problems with new system if 4.4.4 worked fine? Sorry, don't see the relation for broken phone-new software, if something doesn't work it just doesn't work all the time.
hedrox87
the red button is where you put your SIM... like a small square under the flap next to USB
Rickard
@m3lm
Please see my first reply in this thread.
Please keep me updated if it helps or not. Also try draining the battery completely and then charge it full without starting the phone if it doesn't help.
It may be possible that something has gone wrong during the update and caused issues with your phone.
hedrox87
Press it till the phone vibrates 3 times and then release and start up the phone.
hedrox87
OK.. I'll try to drain it to death... It shouldn't be a problem 😉
hedrox87
yes.. the red button didn't help.
30 seconds of charging and then 10 blinks and another 30 seconds of charging. Strange I must say.
m3lm
i pressed the red button untill it vibrated 3 times and turned off then i pressed the power button to start the phone
I didnt felt any change
Im holding it now charging ..but i feel its charging very slow so i think i still have the same problme ...
m3lm
Hi i still having the same issue ...
What else i can do right now ?
my mobile charges in over 10 hours and stucks at 85% only ..
PLEASE HELP ME I STARTED TO REGRET ABOUT UPGRADING TO LOLLIPOP !
hedrox87
Some new facts bout battery lag.
- charged the phone completly OFF and from 5:30 to 9:00 it charged only from 77% to 82%
- waited till 100%, disconnected. Reseted with red button and launch. Stamina said that working time would be around 8 hours. (yesterday it was 3 days 15h).
- Playied "miniclip 8 pool" till 80%. Connected the phone to recharge, but 80% just jumped in a sec. to 100%, like nothing happened.
What is wrong with this lolipop?
Rickard
Sorry to hear that the issue remains.
I will forward this internally but to me this doesn't sound like a software issue i'm afraid.
I'll update you as soon as i have more information.
