my xperia z ultra not charging nor switch on.please solve my problem as soon as possible
Connect your phone to the wall charger > press and hold power & volume up for 5 seconds > let it charge for about 30min > after 30min try to turn it on. Make sure to use the wall charger not the dock or a computer.
Don't forget to give Kudos
Connect your phone to PC hile holding vol up button this will make your notification LED GO BLUE
if this happens your phone is alive just remove your phone and leave it to charge someimes empty battery may cause this leave it for an hour and try again
@uliwooly wrote:Connect your phone to the wall charger > press and hold power & volume up for 5 seconds > let it charge for about 30min > after 30min try to turn it on. Make sure to use the wall charger not the dock or a computer.
Many thanks for the simple but VERY effective information!! My xperia had just rn out of battery charge and not responding when I plugged in the charger. I did as you suggested and it switched on to start charging function...
SO I AM VERY RELIEVED.
KUDOS!
[THANK YOU]
try to repair it with sus the link is HERE download and install it.
After go and select ur phone model and connect ur phone to ur pc.and u can repair ur 4n and i think u can use ur 4n
XPERIA T2ULTRA NOT CHARGING EVEN TRIED PRESSING POWER ON +VOLUME UP KEY BUT IT ALSO DIDNT WORKED
