KEYBOARD TEXTING PROBLEM
vickodera
Hi my cursor jumps from one letter to the letters i don't want texting on keyboard . For example when i touch G, i see the ink spread to F and D,S,A
A. It's really annoying. Someone help fix this please. Victor
techguy
Sorry to break it to ya, but its got to do with the phone heating up after the screen is on more then 5 minutes straight. The touch screen goes haywire when its hot, thats why your cursor jumps. Its a software defect in the kitkat version and more likely is not going to be solved.
Did the keyboard work in other apps other than the default messaging app? I cant use the screen at all when this happens, its jerky and wont work in ANY app. On my phone as soon as this starts i have to reset it by pressing the on button and volume key down at the same time until it vibrates three times. (hard reset)
It will be ok until the next screen heat up.
Sony phones **bleep** so bad Slightly_frowning_Face
13 REPLIES 13
profile.country.RO.title
_alexdon_
Strange,did you try to clear data in settings-apps-all-xperia keyboard?
alexdon
vickodera
What could be the problem and How do i clear the data ?
vickodera
Ok,just done that and the problem still there. From a single touch on the delete button, the ink spreads to the MN
_alexdon_
Do you have a screen protector?
alexdon
techguy
vickodera
Yes,i have a screen protector nicely and tightly stuck on the screen.
_alexdon_
It might be related to that but I won't tell you to remove it if you don't want.
alexdon
SergioPL1
That's a bit wierd.
You can try entering Settings / About phone (last option) / Diagnostics / Test Device / Touch Screen. Try if it paints yellow line where you touch or goes around.
You may also download Multitouch Test app ( https://play.google.com/store/apps/details?id=multitouchpro.tests ) from Play Store and try if the touch is properly recognised.
If not, it may (or may not) be related to the third-party screen protector that causes the trouble. If you are sure that clearing keyboard data, restoring firmware via PC Companion (beware it will delete all your settings, messages, game results) it's the last option you can check yourself.
DisappointedUse
In mine this happens when the screen gets dirty... so I just give it a good clean and problem solved
