is there a way to completely remove or disable the Sony Throw? The reason im asking this is because when i connect my bluetooth headphones, Jaybird X2, Throw is started and it is trying to connect my device, and it prevents me from using them without first closing the Throw notification. Im not sure if Throw is the reason, but Z5 Compact cannot remember my headphones trusted device state either - it will ask it each time i connect them..
The Throw is disabled from the Settings > Device connections > Throw.
The perfect solution would be way to uninstall it...and the other Sony bloatware too.
Cheers
-kimmo
If you're using linux try to sudo your adb command. In windows, you might try to open your command shell with elevated permissions, not sure how to do that. Root is not required for this command.
Edit: permission errors might also be due to not having configured your device to accept adb connections. So, make sure USB debugging is enabled under developer tools section of the settings, set USB to mtp/mass storage and then as you connect to your pc via the USB cable the phone should ask for your permission.
If you ever want to reenable throw you run same command replacing hide by unhide.
Sounds a lot like the trouble I have playing Spotify from BT on my home stereo, will have to have a look what Throw is doing on my phone when this happens.
Just checked it out, and Throw is involved when I have my problems with Spotify when using BT. Thought I had managed to turn it of, but it just keeps coming back.
***Please read and try the posts by TOTOROO first. Note that the method below will PERMANENTLY remove throw from your device***
Dear all, THANKS for the helpful responses - got me on the right track. The problem is now solved with the combo (possibly) of uninstalling playanywhere AND running xperia software repair. I don't know whether software repair alone would have worked, so I'm summarizing both actions below. ADB hide and ADB uninstall did NOT solve the problem on their own.
Summary of my two-step solution:
(1) I UNINSTALLED PLAYAYWHERE USING ADB – SEE STEPS BELOW – “BLOCK” IS NOT AN OPTION IN ADB (I AM RUNNING ANDROID 6) – YOU CAN SEE THE LIST OF CHOICES BELOW. THIS SUCCESSFULLY UNINSTALLED PLAYANYWHERE BUT DID NOT SOLVE THE THROW PROBLEM.
(2) RECEIVED A REPLY FROM SONY TO MY HELP QUERY. THEY SUGGESTED USING XPERIA COMPANION TO PERFORM A SOFTWARE REPAIR. AFTER COMPLETION OF THE SOFTWARE REPAIR, “THROW” IS COMPLETELY GONE, AND BLUETOOTH HAS RUN FOR SEVERAL HOURS WITHOUT A HITCH.
===WARNING: SOFTWARE REPAIR WILL FACTORY RESET YOUR PHONE – YOU WILL NEED TO RESTORE/RE-INSTALL ALL APPS.
STEPS IN DETAIL (AFTER INSTALLING ADB ON WINDOWS LAPTOP, ENABLING DEVELOPER MODE and USB DEBUGGING ON PHONE, CONNECTING PHONE TO LAPTOP, ENABLING MTP):
(1) Disabled bluestacks (TO HAVE ONLY ONE ATTACHED DEVICE FOR ADB)
(2) CONFIRMED ONLY ONE DEVICE FOR ADB
C:\Users\pcuser\AppData\Local\Android\sdk\platform-tools>adb devices
List of devices attached
C*****3G3G device
(3) ATTEMPTED TO BLOCK PLAYANYWHERE AS SOME HAD RECOMMENDED.. ERROR RESULT INCLUDED LIST OF POSSIBLE “PM” COMMANDS (note: had tried “hide” on a previous round, with no success).
C:\Users\pcuser\AppData\Local\Android\sdk\platform-tools>adb shell
shell@E5803:/ $ pm block com.sonymobile.playanywhere
Error: unknown command 'block'
usage: pm list packages [-f] [-d] [-e] [-s] [-3] [-i] [-u] [--user USER_ID] [FIL
TER]
pm list permission-groups
pm list permissions [-g] [-f] [-d] [-u] [GROUP]
pm list instrumentation [-f] [TARGET-PACKAGE]
pm list features
pm list libraries
pm list users
pm path PACKAGE
pm dump PACKAGE
pm install [-lrtsfd] [-i PACKAGE] [--user USER_ID] [PATH]
pm install-create [-lrtsfdp] [-i PACKAGE] [-S BYTES]
[--install-location 0/1/2]
[--force-uuid internal|UUID]
pm install-write [-S BYTES] SESSION_ID SPLIT_NAME [PATH]
pm install-commit SESSION_ID
pm install-abandon SESSION_ID
pm uninstall [-k] [--user USER_ID] PACKAGE
pm set-installer PACKAGE INSTALLER
pm move-package PACKAGE [internal|UUID]
pm move-primary-storage [internal|UUID]
pm clear [--user USER_ID] PACKAGE
pm enable [--user USER_ID] PACKAGE_OR_COMPONENT
pm disable [--user USER_ID] PACKAGE_OR_COMPONENT
pm disable-user [--user USER_ID] PACKAGE_OR_COMPONENT
pm disable-until-used [--user USER_ID] PACKAGE_OR_COMPONENT
pm hide [--user USER_ID] PACKAGE_OR_COMPONENT
pm unhide [--user USER_ID] PACKAGE_OR_COMPONENT
pm grant [--user USER_ID] PACKAGE PERMISSION
pm revoke [--user USER_ID] PACKAGE PERMISSION
pm reset-permissions
pm set-app-link [--user USER_ID] PACKAGE {always|ask|never|undefined}
pm get-app-link [--user USER_ID] PACKAGE
pm set-install-location [0/auto] [1/internal] [2/external]
pm get-install-location
pm set-permission-enforced PERMISSION [true|false]
pm trim-caches DESIRED_FREE_SPACE [internal|UUID]
pm create-user [--profileOf USER_ID] [--managed] USER_NAME
pm remove-user USER_ID
pm get-max-users
(4) CHECKED USER_ID FOR ADB COMMANDS
127|shell@E5803:/ $ dumpsys user
Users:
UserInfo{0:141*****480:13} serialNo=0
Created: <unknown>
Last logged in: +3d23h54m16s747ms ago
(5) SENT UNINSTALL COMMAND WITH ADB
1|shell@E5803:/ $ pm uninstall --user 0 com.sonymobile.playanywhere
Success
(6) SHUT DOWN AND RESTARTED PHONE. NONETHELESS, ALTHOUGH ADB REPORTED SUCCESS FOR THE UNINSTALL, IT HAD NO IMPACT ON “THROW” AND THE FREQUENT DISCONNECT/RECONNECT OF BLUETOOTH.
(7) NEXT DAY, RECEIVED A SUPPORT MESSAGE FROM SONY:
In this case we recommend you to perform a software repair to avoid any memory blocks or glitches on your Sony Xperia device.
Note! Make sure you back up all data before performing a software repair.
To perform a software repair using a Windows® computer
Please click on this link and download: http://support.sonymobile.com/us/xperiaz5compact/tools/xperia-companion/
Your phone must have at least 80% of charge.
click on next.
Once done you will be given the steps on how to connect the phone to the computer:
Note that the first start-up after a software repair may take longer than usual. (ABOUT 5 MINUTES!)
(8) THIS SEEMS TO HAVE SOLVED THE PROBLEM. THROW IS GONE, AS ARE THE PROBLEMS WITH BLUETOOTH DISCONNECT/RECONNECT.
I appreciate the post but there are a few misconceptions about your post. So let's clarify them while at it.
the
pm uninstall package command
will completely uninstall the argument package, no way to go back but reinstall the os.
the pm hide package command
will disable (no root needed) the argument package and you can later on use the complementary pm unhide command to re-enable you package.
Make sure to understand the differences.
Also, have a question, why do you think your pm hide "throw package" didn't work the first time? I assure you, that command completely removed all throw components on my device.
Appreciate the clarifications!
I understand throw is gone forever with this approach.
I'm sorry, I don't know why "hide" didn't work for me. It was one of many failed attempts the previous day - can't remember the failure message. I was not systematic enough with this - trying to fix phone in between getting on with the rest of my life.
I will advise readers to try your solutions carefully before trying mine.
@prg916 wrote:Appreciate the clarifications!
Don't have to be 'sorry'. We're here to help eachother and that's what you did. I appreciate your post and frankly I did learn something new from it.
I can confirm that this command disabled Throw on my Xperia Z2.
Bluetooth connectivity was way better after!
I need to delete throw, can it be done, 99% of your Sony upgrades I don't want. Can I delete those too. My phone is so busy update Sony stuff I wonder who owns it.
Can someon help me? I Just cant get Throw off. I try'd much But it all Just doesnt work. Iam scared That my Phone is deas
i really dont like it and i Dont know what i need to do. I searched on YouTube But i didnt find Anything Can you guys help me?.😭😭😭😭
