I NEED HELP SONY XPERIA Z3 DO NOT LOAD WHEN IT IS COMPLETELY OFF
Gael082
Translation via Google Translate:
Hello, I hope all are very well, The problem that I present is that in my sony xperia z3 it only charges when it is OFF completely, when it is normally started if it is charging, when it is OFF, I completely plug the charger and it only turns on the red LED but it does not He shows the screen what he left more than an hour and he understands and designs that he has 1% battery. Please look for a solution Thank you for your attention.
Hola a todos espero esten muy bien,  El problema que presento es que en mi sony xperia z3 solo carga cuando esta APAGADO completamente, cuando esta ensendido normalmente si carga, cuando esta APAGADO completamente enchufo el cargaor y solo se pone el led rojo pero no me ensiende la pantalla lo e dejado mas de una hora y ensiende y dise que lleva 1% de bateria. Porfavor busco una solucion Gracias por su atencion.
Tags (1)
profile.country.US.title
Qatrium
@Gael082
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
