Hello Sony,
How can I change the message box for incoming text from blue to anohter colour.
When I a new MMS message and the hyper text is blue. I can not read the password as I blue text on blue background.
I would like to have the text in yellow for example. At least then you can have a contrast difference between text and background.
Normal text is OK in white...
I need a soltion ASAP as I use the phone of work and I get about 5 MMS messages a day.... Currently have to use old NON-Sony phone for work.. Would like to use Sony... As I also need the faster performance..
The color of the incoming text message box is controlled by the themed selected in your phone. Change the theme to another one for another color. To change them go to settings > personalization > themes.
Thanks..
Nice.. It works..
Anytime! Glad I could help!
Hi! is it possible to change background color of phone (calling) application to other than white and the titlebar to other than blue? This is kinda tioo bright for me. (Sony Xperia z5 compact)
