Hi @Oulloi,
Welcome to the community,
This sounds like a rather odd issue, let's see if we can help resolve it,
Have you tried any simple troubleshooting such as a reboot to the handset?
Hi Guys,
Is this issue happening every time the device is put on charge or does this only occur after a certain set of parameters are met?
Please let me know.
I got same issue. Every time i charging my XZ, flaslight is dimly lit. Rebooting did not solve the problem.
Hi @ege2117,
Sorry for this inconvenience, however, are you able to answer the above questions for us, we would like to understand how this issue is reproduced.
Appreciate the feedback.
I'm facing the exact same problem...
while charging flashlight is blinking if the battery level is less than %20
I realized that when battery level is up to %50 then stop blinking.
Restarting the device not solved the problem.
Opening and closing the flashlight also were not a solution.
On the other hand when I plug the charger, flashlight blinks once.(usually the battery level is more than %20)
Cheers,
Teo Gen
