Upcoming alarm notification not showing
alexhdkn1
Dear support,
With the latest version of the software the notification of the incoming alarm is not showing thus making me wonder if the alarm is working correctly or not.
Regards,
Alex
Tags (1)
11 REPLIES 11
tomxz1c
Hi there, same problem here. Alarm notification on home screen/status bar is completely missing after the latest update.
profile.country.PT.title
NunoSEN2
Hero
Hi @tomxz1c; @alexhdkn;
I test it in my XZ Premium (same firmware 47.1.A.12.179) and I do get the notification in the the status bar and notifications menu when there are 30 minutes for an upcoming alarm.
Damo_
The upcoming alarm notification displays sometimes for me, maybe once for every five alarms? Can't pinpoint any behaviour for when it does and doesn't appear. I think I've always had this issue though (all the way back to October update) and not something that has started recently.
Edit: Sorry, to make it clearer:
 - The alarm clock icon that sits in the status bar when the alarm is set (next to the WiFi & signal icon) always displays (no issue)
 - It is the separate upcoming alarm notification (which appears 30 mins before the alarm is due to sound) which seems to work sporadically
NunoSEN2
Hero
Hi @Damo_;
I tested it several times and for every time the upcoming alarm notification appeared always, maybe test your device in safe mode to see if same thing happens.
Damo_
Thanks @NunoSEN2, tried that previously but no difference unfortiunately. Also done numerous software repairs over the past few months for a range of other issues but doesn't help. Not end of the world, just another XZ1C thing you learn to live with...
alexhdkn1
Exactly, it's the notification that disappeared.
Edit: I would like to add that the same day that i opened the thread the alarm didn't ring, it only happened that day but still I fear that my phone won't ring in the mornings. Can someone at Sony explore the issue?
Roadrunny76
Enthusiast
Same thing is happening to me on XZ1 (same version 179). The notification sometimes comes up, sometimes not, for the same 8 am alarm (for the other alarms, at earlier hours, the notification is there) . I can not relate this behaviour to any certain action and since between 7:30 & 8 if I turn the alarm off and on the notification comes up, I can assume that it is the clock app at fault.
NunoSEN2
Hero
Well, I did some more testing and what seems to happen is that if you set the alarm to repeat several days it only shows the notification on the first alarm.
Aifaasmudge14
I have just updated my XZ1 to the latest version too and the alarm still not functioning. The notificafions of upcoming alarm and the alarm display were just okay, but no sound came out. Can Sony do something about this? Thank you.
