Hello,
I have a problem trying to make a slow motion video.
When I activate the video mode I see a hand pointing to a sort of dot.
When I click on it the screen start to flicker but I see no button to start the recording.
And if I start a normal record session, I am unable to switch to the slow motion mode.
Am I doing something wrong?
Thank you
This is the Quality of the super slow motion at the time on My mobil
This is normal. Super slowmo is meant to be made in good lighted areas. The lighting conditions in rooms is too bad in most situations. It's best to make recordings outside in the daylight.
Low light -> low video quality
it the same quality outside
Hello,
thank you for the explanation. It looks fine, but when I click on the video recording button,
the slow motion button does not appear.
Hello again,
I tried some more buttons, and maybe I found the reason why it doesn't work.
A message comes up saying that I have to switch to 960 fps, BUT I am unable to find that particular setting. Anyone knows where it is?
Hello @Baldwin;
Here are the instructions for recording slow motion videos: https://support.sonymobile.com/global-en/xperiaxzpremiumdualsim/userguide/moving-objects
Hope it helps.
Regards.
