NO SOUND IF BATTERY IS FULLY LOADED
Franky73
On Android 8 I suddenly have no sound when the battery is fully charged. Also, I do not notice when the battery is at 100%. On Android 7 I did not have this problem.
Does anyone have such a problem? I would be very thankful for help.
Unter Android 8 habe ich plötzlich keinen Ton mehr, wenn der Akku vollständig geladen ist. Auch merke ich nicht, wenn der Akku auf 100% ist. Auf Android 7 hatte ich dieses Problem nicht.
Hat noch jemand so ein Problem? Für Hilfe wäre ich sehr dankbar.
Jonas
Hello everyone!
You might experience that there is no sound notification when the battery is fully charged after updating to Android 8.0 (Oreo). This is an unexpected behaviour that will be corrected in a later software release.
Note! Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models.
Affected software version
  • 41.3.A.0.401
5 REPLIES 5
@Franky73
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
To be honest I've never noticed if it was available as I mute the sounds but I'll see if I can find more info
bonzolika
Yes it's happened with my Xperia xz after the android 8 oreo update, I'm looking for a way around it
ran1
Same here sound issues after Oreo 8.
Upper speaker do not work on loud speaker.
and on voilume adjustment in setting - you can not here the adjsuted sound.....
hope for some rpeiar...
Franky73
I found out, that's an Oreo problem. The fully loaded battery sound don't work under Android 8. I hope it will be fixed with the next update.
Jonas
Hello everyone!
  • 41.3.A.0.401
