samrand69
battery usage
my phone is xz1.
phone idle use the lot of battery. i don't know what can i do about it
Kycpokemon
For "Phone Idle" there is nothing much you can do, because this is software side.
What can help is to
  • Turn on "Airplane Mode" when you are not expecting any calls, texts, etc. For e.g. In class or when you are sleeping
  • Go into Settings -> Network & Internet -> Wi-Fi -> Scroll down and click on Wi-Fi Preferences -> Change "Keep Wi-Fi on during sleep" to anything other than 'Always'.   (Basically what it means is that when your phone is locked, it will not get any information (emails, whatsapp messages, etc.) via Wi-Fi until unlock your phone.
Other than the above 2, there is really nothing much you can do.
To check if the Battery Usage is fine, just see your Screen-on Time, a higher amount means good battery usage. I usually get between 3-6hrs depending on my time spent on gaming.
4 REPLIES 4
profile.country.NL.title
Strampke
There are apps that don't sleep while you do.
- Going to settings->battery>tap on the battery symbol reveals what apps are draining your battery.
- Reading what the experts say can help a lot.
- Find out app behaviour in setting->magnifying glass->search for permission, tap app permission.
Kycpokemon
What can help is to
samrand69
thank you for helping me about this. your ways was very helpful
Kycpokemon
No problem! If this helped, remember to click the Kudos button Slightly_smiling_Face
