my phone is xz1.
phone idle use the lot of battery. i don't know what can i do about it
For "Phone Idle" there is nothing much you can do, because this is software side.
What can help is to
Other than the above 2, there is really nothing much you can do.
To check if the Battery Usage is fine, just see your Screen-on Time, a higher amount means good battery usage. I usually get between 3-6hrs depending on my time spent on gaming.
There are apps that don't sleep while you do.
- Going to settings->battery>tap on the battery symbol reveals what apps are draining your battery.
- Reading what the experts say can help a lot.
- Find out app behaviour in setting->magnifying glass->search for permission, tap app permission.
What can help is to
thank you for helping me about this. your ways was very helpful
No problem! If this helped, remember to click the Kudos button
wrote:thank you for helping me about this. your ways was very helpful
