Battery drain during charging and video call
Auikung
XZ Premium charged to 100%.
During plug with charger, I  start video call on 'LINE' application about 30 minutes.
The battery drain to 77%.
Is is normal?
I never found this event for iPhone FaceTime.
XZ Premium G8142
Android Oreo 8.0.0
Build no. 47.1.A.12.34
3 REPLIES 3
stanlykubrick
For sure a video call will use more battery than a normal phone call with a dark screen. Will it drain faster than the charger can keep up? If you had it charging at the same time it may still have drained but that does seem a little high. I wonder what the percentage of drain would have been if it was not plugged in to a charger?
Auikung
I talk with my friend that have the same problem.
My friend uses the phone and shares wireless hotspot simultaneously while plugging in to ordinary Sony 1.5 A charger.
The battery drained during use the phone. And increase in phone temperature.
This problem was solved by change adapter to quick charge support (QC 2.0) charger.
I hope that Sony will correct this problem by improving the power management software.
May be next patch update.
@Auikung
That's normal, you can even see it with some games, that will drain the battery faster than the phone can recharge the battery; keep in mind that it won't be just that app running but multiple other apps.
