ZR Bluetooth trusted connection
fedoridze
Hello,
Bluetooth doesn't have any checkbox to confirm trusted connection at all, all BT devices to reconnect ask for a code or an admission.
Could not be found at Settings anywhere.
Thks
Sam
Legend
Legend
That is up to the device you are connecting to. In most cases once a device has been paired, so long as the other device also has Bluetooth turned on the phone and device should automatically pair once in range. However some devices will require a code to reconnect with them and unfortunately this cannot be altered by the phone.
