Z5 compact hanging on phone calls made/received
Patdfb
Hi. I upgraded from a Sony XP to a z5 compact white, yesterday, however when i make or recieve phone calls, the phone effectively freezes.screen goes black, even when calls finished!!!
This is especially annoying as the same problem blighted my XP and is one of the main reasons i chose to upgrade as was struggling with ram issues anyway
Brand new phone, and having the exact same issues.
Apps downloaded are
Facebook messenger
Avast anti virus
Ccleaner
Burgerking app
My o2
o2 priority
What is going to be causing the phone part to freeze?
Nb i also have wifi on most of the time
Any help much appreciated
20 REPLIES 20
Patdfb
Well none of it worked still the same
@Patdfb
uninstall any antivirus, taskiller, battery apps > then settings > apps > all > phone > clear data > restart the phone > check again
Patdfb
@uliwooly, done all that after factory reset, but will try again
xavinux
Enthusiast
Hi @Patdfb
If the problem persist after a software repair via PC Companion, I suggest that you contact your Local Sony support for information about how to proceed with this in the best possible way:
Patdfb
I'll try is it normal to have 3 phone apps running at once?
@Patdfb
That's odd, follow @xavinux suggestion and repair the phone with PCC
Patdfb
Done, tis the same, has 3 phone apps after all that
@Patdfb
odd but do you still experience the same issue?
Patdfb
Yip still same
Patdfb
Hi, sorry didnt reply before, the phone had a fault with the membrane which meant that it wasnt behaving properly, on phone calls phone swapped and new one is fine.
Thanks for everyones help
