Z3 Do Not Disturb Problem
MarwaSa
Hi ,,
would you please help me
I have Z3 D6633
I updated it to 6.0.1 months ago
after this update I had a serious problem with sound
when I turn off Do Not Disturb mode , it doesn't off untill I restart the phone
there is no sound even if I make prioity to allow calls
sometimes , when I plug on headphones and then plug off , the same problem
the problem continoue untill I restart the phone
I tried to Volume Up the phone and I tried airplane mode ,, nothing changed
Can you please help me
thanks
47 REPLIES 47
MarwaSa
Dear Sir
yes I reinstall my apps
,, I run the safe mode
and tried to test it ,,
there was no problem ,,
I restart it to normal mode
it works good then the same problem happen
unfortunatley ,, it happens randomly
profile.country.RO.title
_alexdon_
In this case, I think it's one or more of your apps creating this problem. You could try to keep the device in safe mode for 2-3 days, not convenient but kind of efficient.
Or you could remove some of your apps (reverse order than installing, you could use google play store for this as it allows you to easily see and remove them).
alexdon
MarwaSa
I cant use safe mode for long time ..
But
I will try to just install viber,whatsapp and facebook
Is it the same ?
I should note that this problem never happened in Kitkat
_alexdon_
@MarwaSa Not sure if those apps created these issues, might be a different one. Kitkat didn't have DND, also in lollipop it was a bit different. You could uninstall antivirus apps, task killers etc.
alexdon
MarwaSa
Dear Sir .. I will remove all other apps ..
Or should I make repair software then install just important apps ?
Whats the best
I really appreciate your help
Thank you
_alexdon_
If this doesn't take too much of your time, I would suggest you to repair software again and do not install anything else beside those that you really need (try to keep them to a low number and remember them somehow, perhaps make a list that you can later post here in order to get help).
alexdon
MarwaSa
I made a repair software today , and just install ( Whatsapp / Viber / Facebook / Facebbok Mesenger )
I will check it these days and hope it will be OK
Should I remove SD card ??
_alexdon_
Not needed, I don't think it's related. Keep us updated.
alexdon
MarwaSa
OK Sir Slightly_smiling_Face
thanks
MarwaSa
Dear Sir ..
Last night I test DND and then ring normally .. Then I use headphones .. When I woke up today .. I find it doesnt ring when my friends call me ..
What Can I do ? It makes me crazy
I want to know if other people comolain this problem ? Or it is just me ???
Thanks
