x
Z3 dead for 1 day and suddenly working
Elijaho
Hi i have a Z3 xperia it died for no appernt reason for 24h+ ,it didnt respond to charging or any of the resetting key combos no vibrations no leds while charging.
Now it started working ;but i have no mobile connection I cant call or recive calls 'how can i fix this ?
edit:
never mind it fixed itself.....
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
