Check autorotate in quick settings, turn it on, to be able to rotate screen.
Hi @tomislav1
Welcome to the community.
The first thing I would suggest with the speakers is checking to see if this is a potential hardware problem. To use Xperia Diagnostics
Go to Settings > About phone > Diagnostics.
Tap Test device.
Select the Gyroscope
Follow the on-screen instructions.
If it fails the test have a chat with your contact your Local support team as it will need to be serviced.
