Heloo ahmadali123. I think the camera is good, cause zooming in most mobile phones is not so accepted. I can direct you to install an application called : CAMERA FV-5. Give it a try ,I hop you like it.
Do not create other threads. The camera has digital zoom,which means that after you zoom it all,you will get to see the pixels.
different camera settings for different situations, it'll be wise to use manual mode > and change the white balance accordingly
