Brand new Z3V and found that I can connect to my home wi-fi (or any other wi-fi) without problems; but when I leave and return home-I have to to manually reconnect. Shouldn't this phone connect automatically on it own or do I have to reconnect it everytime?
I've searched and cannot find a solution and this is a pain having to connect everytime. Thanks for any help.
If stamina is enabled,wifi will be disabled if you leave your home. See in power management,there is an option called wifi by location.
Settings-power management,there you have the options I was talking about.
Wifi by location was removed in 5.0. I believe you don't have the update on your Z3v,do you?
Once connected to the desired Wi-Fi network, open Settings -> Wi-Fi, tap and hold on your Wi-Fi network and make sure that the option of "Auto-connect" is checked.
