Can't make calls despite of disabling call baring
TinnyBanks
i need help, i dialed code *35*0000# and enabled call barring functionality and later disabled it by dialing #35*0000#. since then i cant make calls with my phone. kindly assist.
6 REPLIES 6
Hampus
That sounds wierd. Do you see that you have any signal strength or that the SIM-card is removed or similar? Could you post a screenshot of your home screen?
Have you tried with another SIM-card in your phone?
TinnyBanks
I haven't tried a different Sim card, b'coz signal is there and I can do other stuff like sms, email, whatsApp etc . I tried to insert my Sim card in a different phone there i can make calls. But putting back to my Xperia can't make calls
mj91
Hi
I have similar problem from 2 days now.
When I try to make a call, dialing is ending after 1/4 signal. I need to try about 10 times to make a call. It's similar when someone is calling. It's like one signal and iI need to be very fast to pick up the phone. And it's not guarantee that I actually will be able speak with someone because sometimes phone hangs up after few sec.
 I can text, use internet etc.
Hampus
If you have tried another SIM-card, but the same thing happens. I suggest that you boot your phone into safe mode to see if you experience the same behaviour:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Otherwise, I suggest that you perform a software repair on your phone via Update Service:
Download and install SUS at your PC, follow the instructions that appear.
electro_nik
Unable to view delivery reports in sms
psefti
My phone just shut down completely after i charged it no reason and now will not turn on nothing happening could it be the battery ?
