Hello,
I have a Xperia Z1 compact.
It charges with 220V.
I have a plan to go to U.S. and Canada.
I would like to know if my XperiaZ1 compact charge with 110V with no problem.
And if it does, do I need anything for converting Voltage (from 220V TO U.S. Voltage)?
It is all related to the adapter you are using,which should convert it to 5V.
excuse me
convert it to 5V or 110 v?
110v is the voltage Which is in U.S.A or Canada.
To 5V,because higher voltage will damage the battery. If you use an original sony charger,there should be no problem.
Thanks.
Anytime,if you need further info,you can contact sony:
